Is there a problem with XWeather chart displays
Postby Myth on Sun Jan 23, 2005 7:09 am
Hi,
Is there a problem with XWeather chart displays, I'm using Jowaldos skin, and the synoptic chart is not diplaying any more ( it did before)
tah
David
Myth
Postby jowaldo on Sun Jan 23, 2005 4:53 pm
did this start happening when you upgraded a version of my skin?
Also my skin doesn't use xweather anymore, it uses the xoap weather plugin.
Postby Myth on Mon Jan 24, 2005 7:05 am
jowaldo wrote:did this start happening when you upgraded a version of my skin?.
No, I'm still using the beta 3 ? version
jowaldo wrote:Also my skin doesn't use xweather anymore, it uses the xoap weather plugin.
My mistake, I am using the xweather plugin for the weather page, but it may have been from another skin as I've mixed and matched my setup from many different skins, but it is primarily your jowaldobeta3 skin
Myth
Postby jowaldo on Mon Jan 24, 2005 5:17 pm
Yeah my skin from beta 3 and earlier uses xweather, from 4 and newer it uses xoap
