DVD Decrypter Plugin by az5
Postby jowaldo on Tue Oct 26, 2004 5:52 pm
az5 (aka Albert) asked me in another post for a place to put a copy of his DVD Dectypter plugin he created. Here it is,
http://www.xlobby.com/files/az5/XLDVDImportPlugin.zip
He included a readme file in the zip on how to install it.
I played around with it a bit and it seems to work pretty good :)
Thanks!
Postby edgley on Wed Oct 27, 2004 12:05 am
oh wow, oh wow, oh wow.
its off to play we go!
edgley
Postby ryang on Fri Oct 29, 2004 4:35 pm
Works pretty good, I was successfully able to rip a dvd to iso mode completely from Xlobby. One thing though, is there a way to specify the name of the iso?
Thanks alot Albert!
ryang
ryang
Postby jowaldo on Fri Oct 29, 2004 6:03 pm
pretty sure there isn't a way, at least in this version
Postby az5 on Sun Oct 31, 2004 8:12 am
Hi,
at the moment there is no way to enter a name for the iso. One possible workaround is to use the [DISC_LABEL] of DVD Decrypter (eg C:\MyDVDs\[DISC_LABEL].iso) as the destination to get different names for each DVD.
Albert
az5
Postby ryang on Mon Nov 01, 2004 8:03 pm
Thanks, I'll try it!
ryang
ryang
Postby edgley on Sun Nov 07, 2004 2:09 am
okay, got a problem.
Install it all, but when I try to confgure, I get the dreaded exception error.
edgley
Postby az5 on Sun Nov 07, 2004 8:42 am
Hi,
version 0.1 does have a bug here. Could you please check the following stuff:
1. DVD Decrypter is installed
2. The path in the registry HKEY_CURRENT_USER\Software\DVD Decrypter\InstallDirectory points to your installation of DVD Decrypter.
Albert
az5
Users browsing this forum: No registered users and 14 guests
