Questions about interfacing with Xlobby...
Postby James4U on Fri Jul 16, 2004 8:09 pm
I have a question, and maybe Steven or someone else can answer them.. :)
I am new to the C# world, xstats being the first programming I have done using C#..
I used to program in C++ years ago, but alot of that has faded away to using php and some VB..
1. In Xlobby you can size and position a text/graphic button on the screen, but how do I get the info from xlobby as to the button size and position?
I see a function in XPluginSDK for SendCommand()..
Do I use this command??
If so, how would I get the info I am looking for??
TIA.. :)
James
James4U
Postby stevenhanna6 on Sun Jul 18, 2004 2:50 am
if you gave the button a "buttonid" I could add something so you can grab that info. Why do you want it?
Postby James4U on Mon Jul 19, 2004 3:53 am
Just looking into creating a plugin for WMP/WinAmp, instead of having to run the program from within Xlobby..
I would like to be able to add things like the visualization window, but need to know the dimensions/position to create the window within the button..
Also, kicking around maybe adding the ability to display the control bar as well..
James4U
Postby badubo on Thu Jul 22, 2004 12:25 pm
I dubble this request :)
Badubo
Member of XLobby FR Team
badubo
Postby stevenhanna6 on Thu Jul 22, 2004 5:16 pm
Alright I have add a new SendCommand() command
"buttonsize:<button id>", this will allow you to retrive the size of a button from a unique button id in the following format <x>:<y>:<width>:<height>. An example of using this would be "buttonid:mybutton", the results would be 10:20:50:40
Postby badubo on Thu Jul 22, 2004 5:19 pm
Thanks Steven :)
Badubo
badubo
Postby stevenhanna6 on Thu Jul 22, 2004 5:20 pm
I might as well mention the new ability to trigger any command from a plugin, see the very end of the SDK on how to do it.
http://www.xlobby.com/Documentation/PluginSDK
