X10 support?
X10 support?
Postby kolemieux on Sat Jul 03, 2004 2:13 pm
I see so many of the great skins with X10 entries, and was wondering what people were doing for X10 support - and or screens - specifically FireCracker? any advice on a plugin to keep the feel within Xlobby.
Thx
kolemieux
Postby jowaldo on Sat Jul 03, 2004 7:13 pm
I use it right now with girder, since there are so many x10 girder firecracker plugins. There are plenty of open source programs to control firecracker devices, so for anyone with good programming skills (not me) should have a good start with those.
For now girder works good for me tho :)
Postby galtigor on Tue Jul 06, 2004 7:13 pm
Well just for fun and to brush up on my C# skills I'm going to take a crack at an x10 plugin. Turns out that HomeSeer provides two ActiveX controls free of charge to allow you to write your own interfaces to the CM11A and CM17 x10 interfaces. I'm going to take a run at hooking this up through Steven's Plugin API.
Should be fairly easy as most of the hardwork will be handled by the Active X objects.
Greg
galtigor
Postby jowaldo on Tue Jul 06, 2004 7:54 pm
Awesome... let me know if you need any help testin it out ;)
X10 Plugin Please.......
Postby kolemieux on Tue Jul 06, 2004 8:30 pm
I WOULD LOVE TO TEST THIS...... certianly let me know if you have anything rough to test when u begin to make progress.
Thanks a ton.
kolemieux
Postby galtigor on Tue Jul 06, 2004 10:37 pm
Ok,
Well I started my investigation and it seems straight forward enough. The only thing I'm trying to figure out now is how variables get passed to the plugin. There seems to be a variable field provided in the Event Manager for passing variables. (In my case it would be the house and control codes) but I can't seem to access it. I think it's done via the GetVariables command but I'm not sure. I could hardcode all the possible code combinations but I don't think I should need to to do that.
Steve can you shed some light on this?
thanks,
Greg
galtigor
Postby stevenhanna6 on Tue Jul 06, 2004 11:57 pm
that stuff gets passed along to the Execute function. If you have an xlobby plugin command it will trigger that plugins Execute function.
GetVariables, is used to get a variable or object from the plugin...like if you have a text box that wants access to an image in the plugin it would call GetVariables.
I'm not what your trying to do exactly, maybe you could write it out in more detail.
Postby galtigor on Wed Jul 07, 2004 3:48 am
In the event manager there are three entries for calling a plugin:
Plugin
Command
Variables
What I want to know is does the Variables entry provide a way for the event manager to send data to the plugin?
If so how do I access the information on that line in the plugin?
For example say I want to have an event like this:
Plugin = x10
Command = Light Off
Variable = A07
So in this example the Light Off command would be sent to the A07 Lamp module shutting the light off.
Greg
galtigor
Postby theendisnye on Wed Jul 07, 2004 6:29 am
I have been doing X10 through XPL using the command line run program. This is a bit crude but works reasonably well and with XPL running I have the ability to run schedules, macros and conditional statements. The command line is a simple execute command 'x10send.exe' and an argument form of ' /command=on /device=a2 /level=10'.
A plug-in XPL interface would really be something.
Steve
theendisnye
Postby galtigor on Wed Jul 07, 2004 4:06 pm
XPL? Not familiar with that. Have you got a link to it? This ActiveX control does have some problems (seems to crash regularly), so I wouldn't mind taking a look at an alternative.
Greg
galtigor
Postby theendisnye on Wed Jul 07, 2004 7:02 pm
There are three or so web sites but here is the key one http://www.xplproject.org.uk
I use;
XPLHAL MANAGER to create macros and conditional events.
XPLCM12 to interface into the CM11/12
X10SEND to send X10 commands from the command line
X10 TTS for text to speech
and I am still looking at other bits so that I can turn on fans if the weather gets hot, using the weather plug in or temp plugin etc
there are some guides which I used to get started
http://www.xplproject.org.uk/modules.ph ... es&secid=3
Steve
theendisnye
Postby badubo on Wed Jul 07, 2004 7:34 pm
Yes, in fact command and variables are concatenated together and send as argument of the execute method of the plugin.
Badubo
Member of XLobby FR Team
badubo
Postby galtigor on Wed Jul 07, 2004 8:21 pm
That was the last part of the puzzle I was having problems with.
Greg
galtigor
Postby galtigor on Sat Jul 10, 2004 9:05 pm
Well it's done and it works with a test program. However it doesn't seem to want to load into Xlobby. I've got all the interfaces needed and it is inheriting Steven's control....
Any help would be nice. :oops:
galtigor
Postby Chicoo on Sun Jul 11, 2004 2:29 pm
The three main things that I can think of are:
- Make sure the plugin is in the plugin directory of Xlobby
- Give the plugin a name through the GetName property. If it does not have a name it will give an empty line in the plugin screen.
- Have the XpluginSDk.dll in the main directory of Xlobby.
These are just some small points that I can think of and that I ran into when creating a plugin.
Chicoo
