XPluginHelper::SendCommand
Postby badubo on Thu Jun 24, 2004 2:16 am
Hello,
According to your documentation, XPluginHelper::SendCommand only accept "invalidate" but in the usb_uirt plugin you use it
i.e. :
this.xhelper.SendCommand("ir>"+command);
How does it work ?
Badubo
Member of XLobby FR Team
badubo
Postby stevenhanna6 on Sun Jun 27, 2004 12:47 am
documentation is incomplete! invalidate is just ONE command, you will be able to trigger ANY of the commands in event manager from a plugin.
How does it work ?
when you make an ir plugin each button should be assigned a unique id, you would send this id to xlobby with that command. But if you look at what the variable command really is it looks like this
ir>irid:128736213
where 128736213 is the unique ir id.
