Baddabing's Modern Metal - Download XLv2 Here
Re: Baddabing's Modern Metal - Download XLv2 Here
Postby SMH on Thu Mar 12, 2009 2:27 am
Baddabing,
Thanks for the quick work in getting a ver. 2 out. I really appreciate it!
Everything looks great; however, the movie cover art still is not appearing in the menu. The CDs are there and everything else seems fine, but the DVD coverart will not appear in the menu screen. Anything I should do or check?
Thanks.
SMH
Postby BaddaBing on Thu Mar 12, 2009 7:12 pm
The skin has two movie screens, one for family and the other for mature material. To do this I use two movie databases:
Create two directories; one for family freindly movies and one for mature. Place the appropriate movies in each directory. The directories can be on a single drive or multpile drives. I have a 6 TB media server so size is not an issue because XL can point at multiple sources per category database.
Import the family movies - then rename the DB movies family (C:\xlobby\databases)
Import the mature movies - then rename the DB movies adult
Each category then has its own display screens
The advantage to this approach is it allows you to easily password protect the adult movies
BaddaBing
Postby SMH on Fri Mar 13, 2009 10:35 pm
Thanks. However, I already had a movies_family database as the Heavy_Metal TS skin had this feature as well.
Anything else to try?
Thanks.
SMH
Previous
Return to Skins
