Vintage skin www
Postby rika on Fri Aug 18, 2006 6:21 am
The feedback on this skin has been great, thanks all!
This skin is done with fireworks (eye candy 4000 plugin for wood and crome. http://www.alienskin.com).
When exporting from layerd png to a psd i have to render all effects otherwise they dont show up right in PS.
So you cant alter the effects in PS, but you can always ad new ones. :wink:
If you want to be able to edit the effects you have to use fireworks and the layerd png fils.
If you come up with somethig good, shere it with us here.
If this makes your day, dont foreget to donate to Steven :wink: That keep this going.
HERE you can find the layerd pngs.
HERE you can find the psd´s
Anybody how want to tweak this skin or "borrow" some buttons for there own skin are free to do so as long as your work not is for commercial use
(Steven excluded...)
Rika
rika
Postby abobader on Fri Aug 18, 2006 1:32 pm
Many thanks rika for the files.
My best.
abobader
Postby XLRETARD on Fri Aug 18, 2006 6:03 pm
WOW!!! :shock: i've been away for a while and i come back to this?!?!?!?!?! :P
this is the best skin EVER!!!!!!!!!!!!!!!!!!!!
rika! next time i'm in sweden i'm gona look you up and give you a big sloppy kiss!
this is the skin i have been dreaming of.....THANK YOU...YOU ROCK!!
BRETT
XLRETARD
Postby rika on Fri Aug 18, 2006 9:22 pm
!!!!XLRETARD !!!!
I think i LIKE!!!!! you... :shock: :D ?!?!
Rika :wink:
rika
Postby sharp_1 on Sat Aug 26, 2006 2:02 pm
Great job Rika!!! This just confirms that fact that I will never be able to learn enough about XL. The moving arrow is the coolest graphics feature I have seen yet!!!
sharp_1
Postby ScAndal on Mon Aug 28, 2006 6:37 pm
OMG are you kidding me? This is the best looking skin for any application I have seen.
You are one of a kind!
ScAndal
Postby rika on Mon Aug 28, 2006 7:56 pm
Thanks!
I think i have spent alitle to much time on this though. Right now i´m feed up with all this vintage stuff... But this vill change i´m sure.
(I have a 16:9 lcd screen with out a fitting skin :wink: )
Rika
rika
Postby P3rv3rt B3ar on Mon Aug 28, 2006 8:04 pm
Rika, any sneak peek possible about your new project? Or atleast info about theme? :P
Have to say that allthough i agree with earlier poster that vintage is best looking skin ive ever seen for any program (actually the reason i was drawn into using xlobby in first place), it doesnt go with my case as well as your dragon, so im sticking with it...
Postby rika on Fri Nov 17, 2006 11:22 am
tips and trick update, see first post.
P3rv. See new post "while we are waiting..."
Rika
rika
Postby T2000 on Sun Dec 17, 2006 6:05 am
Hello Rika & other Xlobby Fans,
Hoping that someone might be able to help me here.
If you want to run this skin, stretched, in any resolution, even 16:9 wide.
just download THIS new background and in vintage skin backgrounds folder change backmenu.jpg
Now you also have to open and edit every .xml screen file. Search and replace :<keepaspectratio>True</keepaspectratio> with <keepaspectratio>False</keepaspectratio>
Done, now you can run vintage skin in any resolution. (This works with any skin)
"edit every .xml screen file..."
PLEASE excuse my ignorance but is this all of the ".xml" files except those starting with "PPC~" ? (that is 102 xml files!)
Any guidance or help would be greatly appreciated!
With conformity comes anonimity,
With individuality come criticism.
T2000
Postby rika on Mon Dec 18, 2006 7:47 am
I will upload a new edited download when a get home.
But yes you have to edit all xml:s :wink:
Rika
rika
Postby lar282 on Mon Dec 18, 2006 1:32 pm
T2000 wrote:Hello Rika & other Xlobby Fans,
download "search and replace" and just select all xml files in the directory (not subs) and then go. Done
//Shaggy
Postby T2000 on Tue Dec 19, 2006 8:21 am
Thanks for the reply lar282...
Jobs right ! :D
Just about to give it a try on my 800x600 touchscreen now!
Thanks again
Regards
Chris
T2000
Postby rika on Tue Dec 19, 2006 1:42 pm
ops, forgot to upload. I will edit first post when i do.
Rika
rika
Re:
Postby deefault on Mon Jul 02, 2007 12:20 am
rika wrote:HERE you can find the layerd pngs.
Rika
Are these files still available (The current link goes to the xlobby homepage)? I love the look of this theme and am interested in trying to create a similar theme in meedio.
Thanks!
deefault
Return to Skins
