French Pack Remote Translation
Postby YaKa12 on Fri Mar 18, 2005 3:07 pm
Hello everyone,
I am busy to translate a documentation from french to english about the "Pack remote" for Xlobby and Girder.
This package allows to assign a different remote key layout to each Xlobby screen.
For example, you can use the play key of your remote to start playing music on a “music section” on your skin, the same key can elsewhere be used to start playing a dvd, a divx, a tv record file and so on.
This package is developed using the ATI Remote Wonder but there is no reasons that it will not do it correctly for other remotes.
To complete the translation I would appreciate if some of you who are interessed in the use of this pack could check/correct this documentation. I am french and my english is not so correct.
Thanks in advance,
Best regards,
YaKa
YaKa12
Return to Documentation
